Seagate 12TB IronWolf Pro 3.5" SATA 6GB/s 7200RPM Hard D...
Seagate 12TB IronWolf Pro 3.5" SATA 6GB/s 7200RPM Hard Drive
£441.88
Select:
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Tough, ready, scalable
  • Actively protect your data with IronWolf health management in popular and enabled NAS
  • Multi-bay and NAS-ready with built-in RV sensor
  • Do more with multi-user optimization
  • Be creative anywhere with IronWolf and your NAS
  • Grow your business NAS
  • Dominate the media
Product codes
For everything NAS, there's IronWolf and IronWolf Pro. Always on and always working, IronWolf is enhanced with AgileArray technology for optimal reliability and system agility. Multi-user technology and extreme workload rates allow IronWolf to perform and scale up with your enterprise.
IronWolf Health Management is designed to operate on compatible NAS systems such as Synology and ASUSTOR. Populated with supported IronWolf or IronWolf Pro HDDs It improves the overall system reliability by displaying actionable prevention, intervention or recovery options for the user.
First in its class, IronWolf drives are equipped with RV sensors on high capacity drives to maintain performance in multi-bay NAS enclosures. RV sensors on IronWolf Pro come standard, helping business and creative pros to have consistent performance for years to come.
Product Description Seagate IronWolf Pro ST12000NE0007 - hard drive - 12 TB - SATA 6Gb/s
Type Hard drive - internal - 24x7 continuous operation, Hot-Plug Support, advanced format 512e, rotation vibration sensor, AgileArray
Capacity 12 TB
Form Factor 3.5"
Interface SATA 6Gb/s
Data Transfer Rate 600 MBps
Buffer Size 256 MB
Spindle Speed 7200 rpm
Features 24x7 continuous operation, Hot-Plug Support, advanced format 512e, rotation vibration sensor, AgileArray
Dimensions (WxDxH) 101.85 mm x 146.99 mm x 26.11 mm
Weight 705 g
Manufacturer Warranty 5-year warranty
Bundled with Seagate Rescue Data Recovery
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Seagate 12TB IronWolf...
£441.88
