Seagate 1TB Backup Plus Ultra Slim USB3.0 Portable Drive Plat...
Seagate 1TB Backup Plus Ultra Slim USB3.0 Portable Drive Platinum
Key features
  • Features mobile backup using the Seagate Mobile Backup App
  • Protect your stuff with easy, flexible backups
  • Back up from Facebook and Flickr and share to YouTube
  • Easy to share files between Windows and Mac computers
  • USB 3.0 plug-and-play with no bulky power supply adapters
Product codes
The Seagate Backup Plus Slim portable drive simplifies backup for consumers who want to help protect their entire digital life locally, in the cloud, from mobile devices or from social networks. The slim, metal design allows you to slide the drive into your pocket, purse or backpack and carry it with you. Via the Seagate Dashboard, use the Protect function to set up a one-click plan or schedule your automatic local backup. Keep multiple copies of your files in case disaster strikes. Install the free Seagate Mobile Backup app on an iOS or Android mobile device to back up all of the pictures and videos from the device to the drive or the cloud. Back up mobile devices via a WiFi connection while at home, or use services like Dropbox or Google Drive while on-the-go, away from home.
With the Save feature, user-generated content can be backed up from your favorite social networks. Capture a memory, post it on a social networking site, and let the Seagate Dashboard automatically back up any content posted, even photos that you are tagged in.
The Share feature allows multiple files to be uploaded to social networks at once from your computer. Simply select files to upload, choose where to post them and even add comments. Managing your social profile has never been easier.
Install the pre-loaded NTFS driver for Mac, and use the drive interchangeably between Windows and Mac computers without reformatting the drive.
Product Description Seagate Backup Plus Slim STEH1000200 - hard drive - 1 TB - USB 3.0
Type Hard drive - external (portable) - automatic backup
Capacity 1 TB
Interface USB 3.0
Data Transfer Rate 5.0 Gbps (USB 3.0)
Features Automatic backup
Power Source USB bus
Enclosure Colour Platinum
Dimensions (WxDxH) 76 mm x 9.6 mm x 113.5 mm
Weight 135 g
Localisation EMEA
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Seagate 1TB Backup Plu...
