Seagate 1TB Constellation.2 SATA-600 7200RPM 64MB 2.5" H...
Seagate 1TB Constellation.2 SATA-600 7200RPM 64MB 2.5" Hard Drive
Key features
  • Maximizes data center footprint with up to 76TB per square foot
  • Energy efficient storage at under 3.9 watts
  • Highest nearline reliability with an MTBF of 1.4M hours
  • 6Gb/s performance in both SAS and SATA interfaces
Product codes
The Seagate Constellation.2 drive is the only 2.5-inch enterprise-class hard drive delivering enterprise reliability at the industry's lowest power consumption for storage-hungry nearline applications. Self-Encrypting Drive (SED) and FIPS 140-2 Validated SED security options are available to help you protect your data.
Product Description Seagate Constellation.2 ST91000640NS - hard drive - 1 TB - SATA 6Gb/s
Type Hard drive - internal - Native Command Queuing (NCQ), Perpendicular Magnetic Recording (PMR), PowerChoice
Capacity 1 TB
Form Factor 2.5"
Interface SATA 6Gb/s
Data Transfer Rate 600 MBps
Buffer Size 64 MB
Spindle Speed 7200 rpm
Features Native Command Queuing (NCQ), Perpendicular Magnetic Recording (PMR), PowerChoice, S.M.A.R.T.
Dimensions (WxDxH) 7 cm x 10.1 cm x 1.5 cm
Weight 200 g
Microsoft Certification Compatible with Windows 7
Manufacturer Warranty 5-year warranty
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
Seagate 1TB Constellat...
