We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
Game Drive for Xbox SSD is Seagate's premium external solid state drive, designed with peak gaming performance in mind. This game drive uses external flash SSD storage to accelerate installation and load times for your Xbox games.
Product Description | Seagate Game Drive for Xbox STHB1000401 - SSD - 1 TB - USB 3.0 | Type | Solid state drive - external (portable) | Capacity | 1 TB | Interface | USB 3.0 | Data Transfer Rate | 5.0 Gbps (USB 3.0) / 480 Mbps (USB 2.0) | Power Source | USB bus | Enclosure Colour | Black | Dimensions (WxDxH) | 93.45 mm x 79 mm x 9.1 mm | Weight | 84 g | Localisation | Worldwide | Manufacturer Warranty | 3-year warranty |
General | |
Device Type | Solid state drive - external (portable) |
Capacity | 1 TB |
Width | 93.45 mm |
Depth | 79 mm |
Height | 9.1 mm |
Weight | 84 g |
Performance | |
Interface Transfer Rate | 5.0 Gbps (USB 3.0) / 480 Mbps (USB 2.0) |
Expansion & Connectivity | |
Interfaces | 1 x USB 3.0 |
Power | |
Miscellaneous | |
Cables Included | 1 x USB 3.0 cable - external - 46 cm |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
