Seagate 1TB Storage Expansion Card for Xbox Series X|S SSD
£229.99
Hurry, only 2 left in stock!
Delivery:
Standard: 1-3 working days
Key features
  • Built-in partnership with Xbox to seamlessly match the full power of both the Xbox Series X and Xbox Series S
  • Add 1 TB of peak performance storage to your Xbox Series X or Xbox Series S without sacrificing performance
  • Compatible with the Xbox Velocity Architecture - providing faster load times, richer environments, and more immersive gameplay
  • Achieve the same performance of the Xbox Velocity Architecture when playing games that have been optimized for Xbox Series X
  • Quick resume means gamers can switch between multiple titles in seconds - from either the internal SSD or the expansion card
  • Easily plug in and play, or remove the card and take your games with you
  • Form Factor: PCI Express
  • Capacity: 1TB, 1TB
  • Interface: U.2 PCIe 3.1 x4 (NVMe)
  • Type: External hard drive
Product codes
Instantly expand the capacity of the powerful gaming experience Xbox has ever created with the Seagate Storage Expansion Card for Xbox Series X/S. Effortlessly compatible with the Xbox Velocity Architecture, experience the fastest load times and most dynamic worlds - with improved performance optimized for Xbox Series X games spanning every Xbox generation. Play at home or take it to a friend's house; peak performance is now at your fingertips.
  • SEAMLESS GAMEPLAY Designed in partnership with Xbox to seamlessly play Xbox Series X|S games from the internal SSD or the expansion card without sacrificing graphics, latency, load times, or framerates
  • HIGH CAPACITY 1TB of storage increases the overall capacity of the Xbox Series X|S—collect thousands of games across four generations of Xbox without sacrificing performance
  • EXCLUSIVE TO XBOX The only available expansion card that replicates the Xbox Velocity Architecture —providing faster load times, richer environments, and more immersive gameplay
  • QUICK RESUME Switch between multiple titles in seconds—directly from the internal SSD or the expansion card
  • WARRANTY Enjoy long-term peace of mind with the included 3-year limited warranty
Product Description Seagate Storage Expansion Card STJR1000400 - interface adapter - PCIe 4.0
Device Type Interface adapter - external
Hard Drive 1 x 1 TB solid state
Interface PCIe 4.0
Supported Devices Solid state drive
Max Storage Devices Qty 1
Dimensions (WxDxH) 3.16 cm x 5.295 cm x 0.78 cm
Weight 30 g
Designed For Xbox Series S, Xbox Series X
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
£229.99
