This HDD for all your PC needs brings you outstanding excellence in personal computing.
Product Description | Seagate Barracuda ST2000DM006 - hard drive - 2 TB - SATA 6Gb/s | Type | Hard drive - internal - Native Command Queuing (NCQ), Halogen Free, Seagate OptiCache technology, Seagate AcuTrac technology, Seagate SmartAlign technology, Hot-Plug Support, TGMR recording technology, advanced format 512e | Capacity | 2 TB | Form Factor | 3.5" | Interface | SATA 6Gb/s | Data Transfer Rate | 600 MBps | Buffer Size | 64 MB | Spindle Speed | 7200 rpm | Features | Native Command Queuing (NCQ), Halogen Free, Seagate OptiCache technology, Seagate AcuTrac technology, Seagate SmartAlign technology, Hot-Plug Support, TGMR recording technology, advanced format 512e, S.M.A.R.T. | Dimensions (WxDxH) | 101.6 mm x 146.99 mm x 26.11 mm | Weight | 626 g | Manufacturer Warranty | 2-year warranty |
General | |
Device Type | Hard drive - internal |
Capacity | 2 TB |
Bytes per Sector | 4096 |
Width | 101.6 mm |
Depth | 146.99 mm |
Height | 26.11 mm |
Weight | 626 g |
Performance | |
Drive Transfer Rate | 600 MBps (external) |
Internal Data Rate | 210 MBps |
Seek Time | 8.5 ms (average) |
Track-to-Track Seek Time | 1 ms |
Average Latency | 4.16 ms |
Reliability | |
Non-Recoverable Errors | 1 per 10^14 |
Load / Unload Cycles | 300,000 |
Expansion & Connectivity | |
Interfaces | 1 x SATA 6 Gb/s |
Compatible Bay | 3.5" |
Power | |
Power Consumption | 8 Watt (active) , 5.4 Watt (idle) , 0.75 Watt (standby) , 0.75 Watt (sleep) |
Miscellaneous | |
Compliant Standards | RoHS |
Manufacturer Warranty | |
Service & Support | Limited warranty - 2 years |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 60 °C |
Min Storage Temperature | -40 °C |
Max Storage Temperature | 70 °C |
Humidity Range Operating | 5 - 95% (non-condensing) |
Shock Tolerance (operating) | 80 g @ 2 ms half-sine pulse |
Shock Tolerance (non-operating) | 300 g @ 2 ms half-sine pulse |
Vibration Tolerance (operating) | 0.5 g @ 22-350 Hz |
Vibration Tolerance (non-operating) | 3 g @ 22-350 Hz |
