Get an HDD for all your PC needs bring you outstanding excellence in personal computing.
Product Description | Seagate Barracuda ST2000DM008 - hard drive - 2 TB - SATA 6Gb/s | Type | Hard drive - internal | Capacity | 2 TB | Form Factor | 3.5" | Interface | SATA 6Gb/s | Data Transfer Rate | 600 MBps | Buffer Size | 256 MB | Spindle Speed | 7200 rpm | Features | Native Command Queuing (NCQ), Halogen Free, Seagate OptiCache technology, Seagate AcuTrac technology, Seagate SmartAlign technology, Hot-Plug Support, Worldwide Name (WWN), TGMR recording technology, S.M.A.R.T. | Dimensions (WxDxH) | 101.6 mm x 146.99 mm x 20.17 mm | Weight | 415 g | Manufacturer Warranty | 2-year warranty |
General | |
Device Type | Hard drive - internal |
Capacity | 2 TB |
Bytes per Sector | 4096 |
Width | 101.6 mm |
Depth | 146.99 mm |
Height | 20.17 mm |
Weight | 415 g |
Performance | |
Drive Transfer Rate | 600 MBps (external) |
Internal Data Rate | 210 MBps |
Seek Time | 8.5 ms (average) |
Track-to-Track Seek Time | 1 ms |
Average Latency | 4.16 ms |
Reliability | |
Non-Recoverable Errors | 1 per 10^14 |
Load / Unload Cycles | 300,000 |
Expansion & Connectivity | |
Interfaces | 1 x SATA 6 Gb/s |
Compatible Bay | 3.5" |
Miscellaneous | |
Compliant Standards | RoHS |
Manufacturer Warranty | |
Service & Support | Limited warranty - 2 years |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 60 °C |
Min Storage Temperature | -40 °C |
Max Storage Temperature | 70 °C |
Humidity Range Operating | 5 - 95% (non-condensing) |
Shock Tolerance (operating) | 80 g @ 2 ms half-sine pulse |
Shock Tolerance (non-operating) | 350 g @ 2 ms half-sine pulse |
Vibration Tolerance (operating) | 0.5 g @ 22-350 Hz |
Vibration Tolerance (non-operating) | 3 g @ 22-350 Hz |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
