Seagate 2TB Expansion USB 3.0 3.5" Desktop Drive
Key features
  • Drag and drop file saving, right out of the box
  • Fast data transfer with USB 3.0 connectivity
  • Simply plug in the included power supply and USB cable
  • The hard drive is automatically recognized by the Windows operating system - no software to install and nothing to configure
  • Drag and drop to save files to the Expansion external hard drive
  • Built-in power management automatically ensures energy-efficient operation
Product codes
Documents
Seagate Expansion desktop drive, add-on storage for your PC
The Seagate® Expansion desktop drive provides extra storage for your ever-growing collection of files. Instantly add space for more files, consolidate all of your files to a single location, or free up space on your computer's internal drive to help improve performance. Setup is straightforward; simply plug in the included power supply and USB cable, and you are ready to go. It is automatically recognized by the Windows® operating system, so there is no software to install and nothing to configure. Saving files is easy too--just drag-and-drop.
Take advantage of the fast data transfer speeds with the USB 3.0 interface by connecting to a SuperSpeed USB 3.0 port. USB 3.0 is backwards compatible with USB 2.0 for additional system compatibility.
  • Windows® 7, Windows Vista®, Windows XP SP3 (32-bit and 64-bit) operating system
  • SuperSpeed USB 3.0 port (required for USB 3.0 transfer speeds or backwards compatible with USB 2.0 ports at USB 2.0 transfer speeds)1
Inside the Box
  • Seagate Expansion drive
  • 4 foot USB 3.0 cable
  • 2-year limited warranty (EMEA)
  • Quick start guide
Seagate Expansion Desktop STBV2000200 - hard drive - 2 TB - USB 3.0
Hard drive - external (desktop)
2 TB
USB 3.0
Power Source
Included AC adapter
Enclosure Colour
118 mm x 179.5 mm x 37.5 mm
940 g
EMEA
2 years warranty
Resources
The following resources are available for the Seagate 2TB Expansion USB 3.0 3.5" Desktop Drive
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Seagate 2TB Expansion...
