The Power of Agility for home, SOHO and SMB NAS enclosures. IronWolf is designed for everything NAS. Get used to tough, ready and scalable 24/7 performance that can handle multi-drive environments with a wide range of capacities.
Product Description | Seagate IronWolf ST2000VN004 - hard drive - 2 TB - SATA 6Gb/s | Type | Hard drive - internal | Capacity | 2 TB | Form Factor | 3.5" | Interface | SATA 6Gb/s | Data Transfer Rate | 600 MBps | Buffer Size | 64 MB | Spindle Speed | 5900 rpm | Features | Halogen Free, NAS compatible, 24x7 availability | Dimensions (WxDxH) | 101.6 mm x 146.99 mm x 26.11 mm | Weight | 535 g | Manufacturer Warranty | 3-year warranty |
General | |
Device Type | Hard drive - internal |
Capacity | 2 TB |
Width | 101.6 mm |
Depth | 146.99 mm |
Height | 26.11 mm |
Weight | 535 g |
Performance | |
Drive Transfer Rate | 600 MBps (external) |
Reliability | |
MTBF | 1,000,000 hours |
24x7 Operation | Yes |
Non-Recoverable Errors | 1 per 10^14 |
Load / Unload Cycles | 600,000 |
Expansion & Connectivity | |
Interfaces | 1 x SATA 6 Gb/s |
Compatible Bay | 3.5" |
Power | |
Power Consumption | 5 Watt (active) , 3.7 Watt (idle) , 0.8 Watt (standby) , 0.8 Watt (sleep) |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years |
Environmental Parameters | |
Min Operating Temperature | 5 °C |
Max Operating Temperature | 70 °C |
Min Storage Temperature | -40 °C |
Max Storage Temperature | 70 °C |
Shock Tolerance (operating) | 80 g @ 2 ms |
Shock Tolerance (non-operating) | 300 g @ 2 ms |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
