Seagate 2TB SkyHawk 3.5" SATA 6Gb/s 64MB Surveillance Ha...
Seagate 2TB SkyHawk 3.5" SATA 6Gb/s 64MB Surveillance Hard Drive
£57.43
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • ImagePerfect firmware supports 24/7 surveillance-optimized workloads tuned to record ~90% of the time and play back video footage the remaining 10%, and supports more cameras recording at higher resolutions than traditional drives
  • Great workload allows SkyHawk to perform reliably in write-intensive surveillance systems - 3x the workload rating of a desktop-class drive
  • Rotational vibration (RV) sensors allow drives to maintain performance in RAID and multi-drive systems, giving customers the flexibility to grow with the booming
  • NVR market and scale their systems when more storage is needed
  • ATA streaming support sustains recordings from up to 64 HD cameras for smooth, uninterrupted footage
  • Lower power consumption means a reduction in heat emissions, which improves reliability in surveillance solutions
  • Tarnish-resistant components help protect drive from environmental elements, increasing field reliability
  • Form Factor: 3.5"
  • Type: Hard drive
  • Interface Type: Serial ATA-600
  • Capacity: 2TB
  • Spin Speed (rpm): 5900rpm
Product codes
Smart. Safe. Secure. Seagate provides drives specifically for surveillance storage for years. SkyHawk is built to keep systems in the field longer and reduce the need for post-deployment support.
Product Description Seagate SkyHawk Surveillance HDD ST2000VX008 - hard drive - 2 TB - SATA 6Gb/s
Type Hard drive - internal - 24x7 availability, ImagePerfect firmware
Capacity 2 TB
Form Factor 3.5"
Interface SATA 6Gb/s
Data Transfer Rate 600 MBps
Buffer Size 64 MB
Spindle Speed 5900 rpm
Features 24x7 availability, ImagePerfect firmware
Dimensions (WxDxH) 101.85 mm x 146.99 mm x 26.11 mm
Weight 610 g
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Seagate 2TB SkyHawk 3....
£57.43
