Seagate 3TB Expansion USB 3.0 Desktop 3.5" External Hard...
Seagate 3TB Expansion USB 3.0 Desktop 3.5" External Hard Drive
£85.46
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Simple add-on storage
  • The easy-to-use storage solution
  • Adds storage capacity instantly
  • Can be installed in seconds
  • Form Factor: 3.5"
  • Capacity: 3TB
  • Interface: USB 3.0
  • Stock Status: In Stock
Product codes
An Easy-To-Use Storage Solution
The Seagate® Expansion™ External hard drive by Seagate offers an easy-to-use solution when you need to add data storage to your computer instantly.
- Drag and drop file saving, right out of the box
- Fast data transfer with USB 3.0 connectivity
The Expansion external hard drive can be installed easily by plugging in two cords. Start saving your digital files to this hard drive within seconds of removing it from the box.
Digital photos, video and music files can tax your computer's storage, causing performance to decline as its internal hard drive fills to capacity.
Seagate® Expansion® External hard drive features make it easy to start using this drive within seconds of removing it from the box:
- Simply plug in the included power supply and USB cable
- The hard drive is automatically recognised by the Windows operating system -- no software to install and nothing to configure
- Drag and drop to save files to the Expansion external hard drive
- Built-in power management automatically ensures energy-efficient operation
What's in the box?
- Seagate Expansion external hard drive
- USB 3.0 cable
- Power adapter
- Quick start guide
- 1-year limited warranty
Product Description Seagate Expansion Desktop STEB3000200 - hard drive - 3 TB - USB 3.0
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Seagate 3TB Expansion...
£85.46
