Seagate 4TB Backup Plus Hub USB3.0 Desktop Hard Drive
Select:
Product codes
Easy backup with integrated USB 3.0 hub to manage and charge your devices
The Seagate® Backup Plus Hub drive optimises external storage with simple local or cloud file backup for your computers and mobile devices - and an intelligent USB hub to charge and manage your USB-connected devices.
High-speed USB 3.0 and 2.0 connectivity offers plug-and-play functionality on your PC. The drive is formatted for Windows computers - install the provided NTFS driver for Mac® on your Mac computer, and you can use the drive interchangeably between Windows and Mac computers without reformatting.
The two front-facing intelligent USB 3.0 ports amplify the functionality of your drive by allowing you to charge and connect two external devices, like your phone, tablet or camera - even if your computer is in off/standby mode.
Via the downloadable Seagate Dashboard software, you are provided with tools for local, mobile, cloud and social media backup. Run a oneclick backup or schedule an automatic backup plan to protect your files in your Backup Plus Hub drive at your convenience.
Install the free Seagate Mobile Backup app on an iOS or Android mobile device, and you’ll be able to back up all of the pictures and videos from your device to your Seagate drive or to the cloud.
Product Description Seagate Backup Plus Hub STEL4000200 - hard drive - 4 TB - USB 3.0
Type Hard drive - external (desktop) - built-in USB hub, NTFS formatted
Capacity 4 TB
Interface USB 3.0
Data Transfer Rate 5.0 Gbps (USB 3.0)
Features Built-in USB hub, NTFS formatted
Power Source Included AC adapter
Dimensions (WxDxH) 41 mm x 198.1 mm x 118 mm
Weight 1.06 kg
Localisation EMEA
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
