Seagate 4TB IronWolf 3.5" SATA 6Gb/s 5900RPM 64MB Hard D...
Seagate 4TB IronWolf 3.5" SATA 6Gb/s 5900RPM 64MB Hard Drive
£107.98
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Optimized for NAS with AgileArray which is built for dual-plane balancing and RAID optimization in multi-bay environments with the most advanced power management possible
  • High performance means no lag times or downtime for users during high traffic time for the NAS
  • Scalable solution for any NAS use-case scenario
  • Get ahead with more cache. IronWolf provides high-cache options allowing your NAS to serve data faster
  • Do more with multi-user technology
  • Multiple users can confidently upload and download data to the NAS server, knowing it can handle the workload, whether you're a creative professional or small business
  • Form Factor: 3.5"
  • Type: Hard drive
  • Interface Type: Serial ATA-600
  • Capacity: 4TB
  • Spin Speed (rpm): 5900rpm
Product codes
The Power of Agility for home, SOHO and SMB NAS enclosures. IronWolf is designed for everything NAS. Get used to tough, ready and scalable 24/7 performance that can handle multi-drive environments with a wide range of capacities.
Product Description Seagate IronWolf ST4000VN008 - hard drive - 4 TB - SATA 6Gb/s
Type Hard drive - internal - Halogen Free, NAS compatible, 24x7 availability, Dual-Plane Balance, Error Recovery Control
Capacity 4 TB
Form Factor 3.5"
Interface SATA 6Gb/s
Data Transfer Rate 600 MBps
Buffer Size 64 MB
Spindle Speed 5900 rpm
Features Halogen Free, NAS compatible, 24x7 availability, Dual-Plane Balance, Error Recovery Control
Dimensions (WxDxH) 101.6 mm x 146.99 mm x 26.11 mm
Weight 610 g
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Seagate 4TB IronWolf 3...
£107.98
