BarraCuda leads the industry with the highest capacities for desktops and mobile computers. The uncompromising BarraCuda Pro marries industry-leading storage capacity with 7,200-RPM spin speeds for snappy performance and load times when gaming or performing heavy workloads.
Get the most out of your storage with BarraCuda hard drives. From computers full of photos and memories to gaming PCs that need more room to play, BarraCuda grows with you.
Product Description | Seagate Guardian BarraCuda ST500LM030 - hard drive - 500 GB - SATA 6Gb/s | Type | Hard drive - internal - QuietStep, Halogen Free, Ramp Load | Capacity | 500 GB | Form Factor | 2.5" | Interface | SATA 6Gb/s | Data Transfer Rate | 600 MBps | Buffer Size | 128 MB | Spindle Speed | 5400 rpm | Features | QuietStep, Halogen Free, Ramp Load | Dimensions (WxDxH) | 69.85 mm x 100.35 mm x 7 mm | Weight | 90 g | Manufacturer Warranty | 2-year warranty |
General | |
Device Type | Hard drive - internal |
Capacity | 500 GB |
Bytes per Sector | 4096 |
Width | 69.85 mm |
Depth | 100.35 mm |
Height | 7 mm |
Weight | 90 g |
Performance | |
Drive Transfer Rate | 600 MBps (external) |
Internal Data Rate | 140 MBps |
Reliability | |
Non-Recoverable Errors | 1 per 10^14 |
Load / Unload Cycles | 600,000 |
Expansion & Connectivity | |
Interfaces | SATA 6 Gb/s |
Compatible Bay | 2.5" |
Power | |
Power Consumption | 1.6 Watt (read) , 1.7 Watt (write) , 0.45 Watt (idle) |
Miscellaneous | |
Compliant Standards | RoHS |
Manufacturer Warranty | |
Service & Support | Limited warranty - 2 years |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 60 °C |
Min Storage Temperature | -40 °C |
Max Storage Temperature | 70 °C |
Shock Tolerance (operating) | 400 g @ 2 ms |
Shock Tolerance (non-operating) | 1000 g @ 1 ms |
