Nothing says "Game Over" for the Xbox One experience like a full hard drive. Boost your console's storage capacity with the Seagate Game Drive, the only external hard drive designed exclusively for Xbox.
Product Description | Seagate Game Drive for Xbox STHB500401 - solid state drive - 500 GB - USB 3.0 | Type | Solid state drive - external (portable) | Capacity | 500 GB | Interface | USB 3.0 | Data Transfer Rate | 5.0 Gbps (USB 3.0) / 480 Mbps (USB 2.0) | Power Source | USB bus | Enclosure Colour | Black | Dimensions (WxDxH) | 93.45 mm x 79 mm x 9.1 mm | Weight | 84 g | Localisation | Worldwide | Manufacturer Warranty | 3-year warranty | Designed For | Xbox One X |
General | |
Device Type | Solid state drive - external (portable) |
Capacity | 500 GB |
Width | 93.45 mm |
Depth | 79 mm |
Height | 9.1 mm |
Weight | 84 g |
Performance | |
Interface Transfer Rate | 5.0 Gbps (USB 3.0) / 480 Mbps (USB 2.0) |
Expansion & Connectivity | |
Interfaces | 1 x USB 3.0 |
Power | |
Miscellaneous | |
Cables Included | 1 x USB 3.0 cable - external - 46 cm |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years |
Compatibility Information | |
