Seagate 600GB 10,000RPM 128MB 12Gb/s SAS 2.5" Enterprise...
Seagate 600GB 10,000RPM 128MB 12Gb/s SAS 2.5" Enterprise HDD
£139.05
Hurry, only 2 left in stock!
Delivery:
Standard: 1-3 working days
Key features
  • Maximize storage investments for the long haul
  • Superior data security features
Product codes
The Seagate Enterprise Performance 10K HDD is an ideal 1.2 TB hard drive for mission critical applications. It delivers best-in-class mission critical random performance, highest capacities and the low power that data centers need to meet demanding service level agreements and to keep up with data growth and reduce IT operating costs.
Seagate Exos 10E2400 ST600MM0218 - hard drive - 600 GB - SAS 12Gb/s
Hard drive - internal
600 GB
Hardware Encryption
Encryption Algorithm
256-bit AES-XTS
2.5" SFF
SAS 12Gb/s
Data Transfer Rate
1.2 GBps
Buffer Size
128 MB
Spindle Speed
10000 rpm
Idle Read After Write (IRAW), PowerChoice, Error Correction Code (ECC), Seagate RAID Rebuild, LED status indicator, Dual Port, upgradable firmware, advanced format 512n, Drive Self Test (DST), S.M.A.R.T.
70.1 mm x 100.45 mm x 15 mm
222 g
5 years warranty
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Seagate 600GB 10,000RP...
£139.05
