SkyHawk leverages Seagate's extensive experience in designing drives purpose-built for surveillance applications.
Product Description | Seagate SkyHawk Surveillance HDD ST6000VX001 - hard drive - 6 TB - SATA 6Gb/s | Type | Hard drive - internal | Capacity | 6 TB | Form Factor | 3.5" | Interface | SATA 6Gb/s | Data Transfer Rate | 600 MBps | Buffer Size | 256 MB | Features | Surveillance system compatible, ImagePerfect firmware | Dimensions (WxDxH) | 101.85 mm x 146.99 mm x 26.11 mm | Weight | 610 g | Manufacturer Warranty | 3-year warranty |
General | |
Device Type | Hard drive - internal |
Capacity | 6 TB |
Width | 101.85 mm |
Depth | 146.99 mm |
Height | 26.11 mm |
Weight | 610 g |
Performance | |
Drive Transfer Rate | 600 MBps (external) |
Internal Data Rate | 180 MBps |
Reliability | |
MTBF | 1,000,000 hours |
Non-Recoverable Errors | 1 per 10^14 |
Load / Unload Cycles | 300,000 |
Expansion & Connectivity | |
Interfaces | 1 x SATA 6 Gb/s |
Compatible Bay | 3.5" |
Power | |
Power Consumption | 5 Watt (active) , 3.4 Watt (idle) , 0.25 Watt (sleep) , 0.25 Watt (standby) |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 70 °C |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
