Seagate 6TB SkyHawk 3.5" SATA 6Gb/s 256MB Surveillance H...
Seagate 6TB SkyHawk 3.5" SATA 6Gb/s 256MB Surveillance Hard Drive
£165.92
32 in stock
Delivery:
Standard: 1-3 working days
Key features
  • ImagePerfect firmware supports 24/7 surveillance-optimized workloads tuned to record ~90% of the time and play back video footage the remaining 10%, and supports more cameras recording at higher resolutions than traditional drives
  • Great workload allows SkyHawk to perform reliably in write-intensive surveillance systems - 3x the workload rating of a desktop-class drive
  • Rotational vibration (RV) sensors allow drives to maintain performance in RAID and multi-drive systems, giving customers the flexibility to grow with the booming
  • NVR market and scale their systems when more storage is needed
  • ATA streaming support sustains recordings from up to 64 HD cameras for smooth, uninterrupted footage
  • Lower power consumption means a reduction in heat emissions, which improves reliability in surveillance solutions
  • Tarnish-resistant components help protect drive from environmental elements, increasing field reliability
Product codes
Smart. Safe. Secure. Seagate provides drives specifically for surveillance storage for years. SkyHawk is built to keep systems in the field longer and reduce the need for post-deployment support.
Seagate SkyHawk Surveillance HDD ST6000VX0023 - hard drive - 6 TB - SATA 6Gb/s
Hard drive - internal
6 TB
3.5"
SATA 6Gb/s
Data Transfer Rate
600 MBps
Buffer Size
256 MB
Spindle Speed
7200 rpm
RV Sensor, 24x7 availability, ImagePerfect firmware
101.85 mm x 146.99 mm x 26.11 mm
705 g
3 years warranty
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Seagate 6TB SkyHawk 3....
£165.92
