Seagate 8TB Enterprise 3.5" HDD SATA 6Gb/s
£294.31
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Quickly access and store critical data with blazingly fast random performance
  • Enjoy peace of mind with field-proven, ninth-generation technology for reliable access to unstructured data - all in the same 3.5-inch footprint
  • Helps to ensure 24Ă—7 uninterrupted performance - every transaction, every day
  • Efficiently delivers easy integration into replicated and RAID bulk storage systems with 12Gb/s SAS and SATA 6Gb/s interface options
  • Form Factor: 3.5" x 1/3H
  • Type: Hard drive
  • Interface Type: Serial ATA-600
  • Capacity: 8TB
  • Spin Speed (rpm): 7200rpm
Product codes
Supporting the industry's best response times for an 8TB a nearline drive, the Seagate Enterprise Capacity 3.5 HDD enables the fastest data transfers thanks to comprehensive advanced caching technology. Meet your storage workload requirements in the most efficient and cost-effective data center footprint available on the market. With innovative technology advancements like PowerBalance, PowerChoice and RAID Rebuild, you can customize your bulk storage requirements for even greater improvements in your TCO.
Product Description Seagate Exos 7E8 ST8000NM0055 - hard drive - 8 TB - SATA 6Gb/s
Type Hard drive - internal - PowerChoice, T10 Protection Information (T10 PI), Seagate RAID Rebuild, Humidity Sensor, Low Halogen, Super Parity, Power Balance technology, advanced format 512e, 24x7 availability
Capacity 8 TB
Form Factor 3.5" x 1/3H
Interface SATA 6Gb/s
Data Transfer Rate 600 MBps
Buffer Size 256 MB
Spindle Speed 7200 rpm
Features PowerChoice, T10 Protection Information (T10 PI), Seagate RAID Rebuild, Humidity Sensor, Low Halogen, Super Parity, Power Balance technology, advanced format 512e, 24x7 availability
Dimensions (WxDxH) 101.85 mm x 147 mm x 26.1 mm
Weight 780 g
Microsoft Certification Compatible with Windows 7
Manufacturer Warranty 5-year warranty
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Seagate 8TB Enterprise...
£294.31
