Seagate 8TB Game Drive Hub for Xbox
£158.86
Hurry, only 3 left in stock!
Delivery:
Standard: 1-3 working days
Key features
  • Dual front-facing USB 3.0 ports
  • Plug-and-play setup that gets you playing in seconds
  • High-speed USB 3.0 performance
  • Form Factor: 3.5"
  • Capacity: 8TB
  • Stock Status: In Stock
Product codes
WithThe Game Drive Hub for Xbox allows you to stretch out with a colossal 8 TB — plenty of room to install 200+ games. Easily take care of your game storage needs and make deleting old games a thing of the past. Plus, all that extra space is useful for the sizeable game-save data and downloadable content you’ll want to hold on to.
Product Description Seagate Game Drive Hub for Xbox STGG8000400 - hard drive - 8 TB - USB 3.0
Type Hard drive - external (portable) - built-in USB hub
Capacity 8 TB
Interface USB 3.0
Data Transfer Rate 5.0 Gbps (USB 3.0)
Features Built-in USB hub
Power Source USB bus
Enclosure Colour White
Dimensions (WxDxH) 41 mm x 198.11 mm x 118 mm
Weight 0.89 kg
Localisation Worldwide
Manufacturer Warranty 1-year warranty
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Seagate 8TB Game Drive...
£158.86
