Seagate 8TB IronWolf Pro 3.5" SATA 6GB/s 7200RPM Hard Drive
£245.88
Select:
  • 8TB
Delivery:
Key features
  • Optimized for NAS with AgileArray
  • High performance means reduced lag times
  • Seagate rescue data recovery
  • Rotational Vibration (RV) mitigation
  • Do more with multi-user technology
  • Designed for always on, always accessible 24 x 7 performance
  • Form Factor: 3.5"
  • Type: Hard drive
  • Capacity: 8TB
  • Spin Speed (rpm): 7200rpm
Product codes
IronWolf Pro is designed for everything business NAS. Get used to tough, ready and scalable 24 x 7 performance that can handle multi-drive environments.
Product Description Seagate IronWolf Pro ST8000NE0004 - hard drive - 8 TB - SATA 6Gb/s
Type Hard drive - internal - Hot-Plug Support, advanced format 512e, 24x7 availability, rotation vibration sensor, AgileArray
Capacity 8 TB
Form Factor 3.5"
Interface SATA 6Gb/s
Data Transfer Rate 600 MBps
Buffer Size 256 MB
Spindle Speed 7200 rpm
Features Hot-Plug Support, advanced format 512e, 24x7 availability, rotation vibration sensor, AgileArray
Dimensions (WxDxH) 101.85 mm x 146.99 mm x 26.11 mm
Weight 650 g
Manufacturer Warranty 5-year warranty
Bundled with Seagate Rescue Data Recovery
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Seagate 8TB IronWolf P...
£245.88
