ImagePerfect firmware supports 24/7 surveillance-optimized workloads tuned to record ~90% of the time and play back video footage the remaining 10%, and supports more cameras recording at higher resolutions than traditional drives
Great workload allows SkyHawk to perform reliably in write-intensive surveillance systems - 3x the workload rating of a desktop-class drive
Rotational vibration (RV) sensors allow drives to maintain performance in RAID and multi-drive systems, giving customers the flexibility to grow with the booming
NVR market and scale their systems when more storage is needed
ATA streaming support sustains recordings from up to 64 HD cameras for smooth, uninterrupted footage
Lower power consumption means a reduction in heat emissions, which improves reliability in surveillance solutions
Tarnish-resistant components help protect drive from environmental elements, increasing field reliability
Smart. Safe. Secure. Seagate provides drives specifically for surveillance storage for years. SkyHawk is built to keep systems in the field longer and reduce the need for post-deployment support.
Seagate SkyHawk Surveillance HDD ST8000VX0022 - hard drive - 8 TB - SATA 6Gb/s
