Seagate Cheetah 15K.7 300GB 3.5IN 15K RPM 16MB SAS2
Key features
  • Third-generation perpendicular recording
  • Unprecedented performance with sustained data rate of up to 204MB/s - a 16 percent increase over last generation
  • High 3.5-inch drive reliability
  • Seagate PowerTrim technology provides a 62 percent improvement in GBs/W at idle over typical 3.5-inch hard drives
  • Read/write advances deliver nonrecoverable error rate of 1x10E16
  • TCG-compliant Self-Encrypting Drive (SED) option cuts IT drive retirement expenses while securely protecting data
Product codes
Seventh-generation Seagate Cheetah 15K.7 drive is the fastest, highest capacity and most reliable ever. Lower watts/GB ratio helps achieve reduced power and cooling costs while optimizing capacity requirements. Higher performance with fewer drives - reducing support infrastructure, physical space requirements and storage management costs. The highest reliability of any 3.5-inch drive, with increased system reliability due to the need for fewer drives.
Seagate Cheetah 15K ST3300657SS - hard drive - 300 GB - SAS 6Gb/s
Hard drive - internal
300 GB
3.5" x 1/3H
SAS 6Gb/s
Data Transfer Rate
600 MBps
Buffer Size
16 MB
Spindle Speed
15000 rpm
Enhanced Error Correction Code, Background Media Scan (BMS), PowerTrim technology, Perpendicular Magnetic Recording (PMR)
10.2 cm x 14.7 cm x 2.5 cm
0.67 kg
Microsoft Certification
Compatible with Windows 7
5 years warranty
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Seagate Cheetah 15K.7...
