Seagate Exos 10TB X-Class Nearline Enterprise 3.5" SATA III
£322.75
14 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Advanced Write Caching feature for 20% boost in random write performance over last-generation HDDs
  • Reduced TCO thanks to reduced power and cooling costs and lower weight
  • Integrates easily in hyperscale and high-density data center applications with both SATA and SAS interfaces
  • Robust wide-weld sealed drive design and field-proven technology for long-term reliability
  • Protect data where it lives - on the drive - with Seagate Secure Self-Encrypted Drive technology
Product codes
The Seagate Enterprise Capacity 3.5 HDD (Helium) lets you turbocharge data transfers with dependably fast read/write performance. Meet your workload requirements while minimizing your data center footprint. Manage increasing volumes of data in cloud data centers much faster thanks to advanced write caching algorithms.
Seagate Exos X10 ST10000NM0086 - hard drive - 10 TB - SATA 6Gb/s
Hard drive - internal
10 TB
3.5" x 1/3H
SATA 6Gb/s
Data Transfer Rate
600 MBps
Buffer Size
256 MB
Spindle Speed
7200 rpm
Temperature sensor, Enterprise Class Reliability, PowerChoice, Humidity Sensor, Low Halogen, Super Parity, Hot-Plug Support, PowerBalance, advanced format 512e, 24x7 availability, Organic Solderability Preservative, Multi-Step Forged Helium Sealed-Drive design, Superior Wide-Weld Hermetically Sealed-Drive enclosure, pressure sensor, Advanced Write Caching
101.85 mm x 147 mm x 26.11 mm
650 g
5 years warranty
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Seagate Exos 10TB X-Cl...
£322.75
