Seagate Exos 10TB X-Class Nearline Enterprise 7200RPM 3.5&quo...
Seagate Exos 10TB X-Class Nearline Enterprise 7200RPM 3.5" 256MB Hard Drive
£327.91
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Built for speed - exactly where it is needed
  • Incredibly high capacity paired with world-class reliability
Product codes
Among the industry's best response times for a nearline drive, the Seagate Enterprise Capacity 3.5 HDD (Helium) helps enable some of the fastest data transfers possible. Meet your storage workload requirements with an efficient data center footprint. Innovative technology advancements like PowerBalance, PowerChoice and RAID Rebuild, allow you to have the control to customise your bulk storage requirements for even greater TCO improvements.
Seagate Exos X10 ST10000NM0016 - hard drive - 10 TB - SATA 6Gb/s
Hard drive - internal - nearline
10 TB
3.5" x 1/3H
SATA 6Gb/s
Data Transfer Rate
600 MBps
Buffer Size
256 MB
Spindle Speed
7200 rpm
Temperature sensor, T10 Protection Information (T10 PI), Seagate RAID Rebuild, Humidity Sensor, Low Halogen, Super Parity, Hot-Plug Support, Power Balance technology, advanced format 512e, 24x7 availability, Helium technology, Power Choice Idle Power technology, Power Choice Power/Performance technology, Organic Solderability Preservative, Multi-Step Forged Helium Sealed-Drive design, Superior Wide-Weld Hermetically Sealed-Drive enclosure, pressure sensor, S.M.A.R.T.
101.85 mm x 147 mm x 26.11 mm
650 g
5 years warranty
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Seagate Exos 10TB X-Cl...
£327.91
