Seagate Exos 10TB X-Class Nearline Enterprise 7200RPM 3.5&quo...
Seagate Exos 10TB X-Class Nearline Enterprise 7200RPM 3.5" 256MB Hard Drive
£302.23
Hurry, only 1 left in stock!
Delivery:
Standard: 1-3 working days
Key features
  • Advanced Write Caching feature for 20% boost in random write performance over last-generation HDDs
  • Reduced TCO thanks to reduced power and cooling costs and lower weight
  • Integrates easily in hyperscale and high-density data center applications with both SATA and SAS interfaces
  • 24×7 data availability backed by a 2.5M-hour MTBF and 5-year limited warranty
  • Robust wide-weld sealed drive design and field-proven technology for long-term reliability
  • Protect data where it lives - on the drive - with Seagate Secure Self-Encrypted Drive technology
  • Form Factor: 3.5" x 1/3H
  • Type: Hard drive
  • Interface Type: SAS
  • Capacity: 10TB
  • Spin Speed (rpm): 7200rpm
Product codes
The Seagate Enterprise Capacity 3.5 HDD (Helium) lets you turbocharge data transfers with dependably fast read/write performance. Meet your workload requirements while minimizing your data center footprint. Manage increasing volumes of data in cloud data centers much faster thanks to advanced write caching algorithms.
Product Description Seagate Exos X10 ST10000NM0096 - hard drive - 10 TB - SAS 12Gb/s
Type Hard drive - internal - temperature sensor, Enterprise Class Reliability, PowerChoice, Humidity Sensor, Low Halogen, Super Parity, Hot-Plug Support, T10 Data Integrity Field (DIF), PowerBalance, advanced format 512e, 24x7 availability, Organic Solderability Preservative, Multi-Step Forged Helium Sealed-Drive design, Superior Wide-Weld Hermetically Sealed-Drive enclosure, pressure sensor, Advanced Write Caching
Capacity 10 TB
Form Factor 3.5" x 1/3H
Interface SAS 12Gb/s
Data Transfer Rate 1.2 GBps
Buffer Size 256 MB
Spindle Speed 7200 rpm
Features Temperature sensor, Enterprise Class Reliability, PowerChoice, Humidity Sensor, Low Halogen, Super Parity, Hot-Plug Support, T10 Data Integrity Field (DIF), PowerBalance, advanced format 512e, 24x7 availability, Organic Solderability Preservative, Multi-Step Forged Helium Sealed-Drive design, Superior Wide-Weld Hermetically Sealed-Drive enclosure, pressure sensor, Advanced Write Caching
Dimensions (WxDxH) 101.85 mm x 147 mm x 26.11 mm
Weight 650 g
Manufacturer Warranty 5-year warranty
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Seagate Exos 10TB X-Cl...
£302.23
