Seagate Exos 12TB X-Class Nearline Enterprise 7200RPM 3.5&quo...
Seagate Exos 12TB X-Class Nearline Enterprise 7200RPM 3.5" 256MB Hard Drive
£397.75
Delivery:
Key features
  • Low power and weight for optimum data center TCO
  • High HDD performance with enhanced caching, making it perfect for Big Data applications
  • PowerBalance feature optimizes IOPS/Watt
  • Advanced Write Caching feature for excellent boost in random write performance
  • Forged, wrought-aluminum base and a helium sealed-drive design with no porosity and uniform density
  • Superior material and weld-width design for a more robust, hermetically sealed-drive enclosure that protects from helium leaks
  • Digital environmental sensors for measuring internal pressure, helping to ensure high reliability, performance and quality
  • Hermetic interconnect technology supporting higher data rate heads and higher pin counts for extreme thermal conditions
Product codes
Marketing description is not available.
Seagate Exos X12 ST12000NM0007 - hard drive - 12 TB - SATA 6Gb/s
Hard drive - internal
12 TB
3.5"
SATA 6Gb/s
Data Transfer Rate
600 MBps
Buffer Size
256 MB
Spindle Speed
7200 rpm
Seagate Secure, PowerChoice, Seagate RAID Rebuild, Low Halogen, Super Parity, Hot-Plug Support, Power Balance technology, advanced format 512e, 24x7 availability, Helium technology, Organic Solderability Preservative, Multi-Step Forged Helium Sealed-Drive design, Superior Wide-Weld Hermetically Sealed-Drive enclosure, pressure sensor, Advanced Write Caching
101.6 mm x 147 mm x 26.11 mm
650 g
5 years warranty
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Seagate Exos 12TB X-Cl...
£397.75
