Seagate Exos 12TB X-Class Nearline Enterprise 7200RPM 3.5&quo...
Seagate Exos 12TB X-Class Nearline Enterprise 7200RPM 3.5" 256MB Hard Drive
£415.02
14 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Low power and weight for optimum data center TCO
  • High HDD performance with enhanced caching, making it perfect for Big Data applications
  • PowerBalance feature optimizes IOPS/Watt
  • Advanced Write Caching feature for excellent boost in random write performance
  • Forged, wrought-aluminum base and a helium sealed-drive design with no porosity and uniform density
  • Superior material and weld-width design for a more robust, hermetically sealed-drive enclosure that protects from helium leaks
  • Digital environmental sensors for measuring internal pressure, helping to ensure high reliability, performance and quality
  • Hermetic interconnect technology supporting higher data rate heads and higher pin counts for extreme thermal conditions
Product codes
Marketing description is not available.
Seagate Exos X12 ST12000NM0027 - hard drive - 12 TB - SAS 12Gb/s
Hard drive - internal
12 TB
3.5"
SAS 12Gb/s
Data Transfer Rate
1.2 GBps
Buffer Size
256 MB
Spindle Speed
7200 rpm
Seagate Secure, PowerChoice, T10 Protection Information (T10 PI), Seagate RAID Rebuild, Dual Port, Low Halogen, Super Parity, Hot-Plug Support, Power Balance technology, advanced format 512e, 24x7 availability, Helium technology, Organic Solderability Preservative, Multi-Step Forged Helium Sealed-Drive design, Superior Wide-Weld Hermetically Sealed-Drive enclosure, pressure sensor, Advanced Write Caching
101.6 mm x 147 mm x 26.11 mm
650 g
5 years warranty
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Seagate Exos 12TB X-Cl...
£415.02
