The Seagate Enterprise Capacity 2.5 HDD is the only 2.5-inch enterprise-class hard drive delivering high capacities and enterprise reliability at the industry's lowest power per watt for storage-hungry nearline applications.
The Enterprise Capacity 2.5 HDDs reduce per-gigabyte cooling and energy costs by packing high capacities into an SFF, low-power-consumption drive.
The Enterprise Capacity 2.5 HDDs can help you deploy additional enterprise storage without expanding your data center.
Product Description | Seagate Exos 7E2000 ST2000NX0273 - hard drive - 2 TB - SAS 12Gb/s | Type | Hard drive - internal - nearline | Capacity | 2 TB | Form Factor | 2.5" SFF | Interface | SAS 12Gb/s | Data Transfer Rate | 1.2 GBps | Buffer Size | 128 MB | Spindle Speed | 7200 rpm | Features | PowerChoice, Secure Drive, Seagate RAID Rebuild, Low Halogen | Dimensions (WxDxH) | 70.1 mm x 100.45 mm x 15 mm | Weight | 198 g | Microsoft Certification | Compatible with Windows 7 | Manufacturer Warranty | 5-year warranty |
General | |
Device Type | Hard drive - internal - nearline |
Capacity | 2 TB |
Width | 70.1 mm |
Depth | 100.45 mm |
Height | 15 mm |
Weight | 198 g |
Performance | |
Drive Transfer Rate | 1.2 GBps (external) |
Internal Data Rate | 136 MBps |
Average Latency | 4.16 ms |
Reliability | |
MTBF | 1,400,000 hours |
Non-Recoverable Errors | 1 per 10^15 |
Expansion & Connectivity | |
Interfaces | 2 x SAS 12 Gb/s |
Compatible Bay | 2.5" SFF |
Power | |
Power Consumption | 3.53 Watt (idle) , 6.02 Watt (read) , 1.52 Watt (standby) |
Miscellaneous | |
Compatible with Windows 7 | "Compatible with Windows 7" software and devices carry Microsoft’s assurance that these products have passed tests for compatibility and reliability with 32-bit and 64-bit Windows 7. |
Manufacturer Warranty | |
Service & Support | Limited warranty - 5 years |
Environmental Parameters | |
Min Operating Temperature | 5 °C |
Max Operating Temperature | 55 °C |
Shock Tolerance (operating) | 25 g @ 2 ms |
Shock Tolerance (non-operating) | 400 g @ 2 ms |
Vibration Tolerance (operating) | 0.5 g @ 5-500 Hz |
Vibration Tolerance (non-operating) | 3 g @ 5-500 Hz |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
