We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
The Savvio 15K.3 drive enables Tier 1 applications to read and write both random and sequential data faster. Data centers can store and access important random data up to 10% faster and sequential data up to 21% faster over previous generations, enabling them to process more transactions within a given time period.
Providing up to 300 GB capacity, the Seagate Savvio 15K.3 drive stores twice the amount of data without increasing the total number hard drives used. This helps data centers keep up with the growth of data while improving storage efficiency.
The Savvio 15K.3 drive provides protection information and self-encrypting drive options to help companies achieve corporate and/or government security compliance goals. The drive helps protect data from inadvertent change from the moment of creation until the end of life, and from exposure if the device is lost, stolen or retired.
Product Description | Seagate Exos 15E900 ST300MP0106 - hard drive - 300 GB - SAS 12Gb/s | Type | Hard drive - internal | Capacity | 300 GB | Form Factor | 2.5" SFF | Interface | SAS 12Gb/s | Data Transfer Rate | 2400 MBps | Buffer Size | 256 MB | Spindle Speed | 15000 rpm | Features | Dual Port, Humidity Sensor, Low Halogen, Hot-Plug Support, Seagate TurboBoost, advanced format 512e, advanced format 4Kn, 24x7 availability, Power Choice Idle Power technology, Organic Solderability Preservative, Advanced Write Caching, Intelligent NAND Endurance Management, Seagate Fast Format | Dimensions (WxDxH) | 69.85 mm x 100.45 mm x 15 mm | Weight | 225 g | Manufacturer Warranty | 5-year warranty |
General | |
Device Type | Hard drive - internal |
Capacity | 300 GB |
Width | 69.85 mm |
Depth | 100.45 mm |
Height | 15 mm |
Weight | 225 g |
Performance | |
Drive Transfer Rate | 2400 MBps (external) |
Internal Data Rate | 315 MBps |
Average Latency | 2 ms |
Reliability | |
24x7 Operation | Yes |
Non-Recoverable Errors | 1 per 10^16 |
Expansion & Connectivity | |
Interfaces | 2 x SAS 12 Gb/s |
Compatible Bay | 2.5" SFF |
Power | |
Power Consumption | 4.7 Watt (idle) , 6.9 Watt (active) |
Manufacturer Warranty | |
Service & Support | Limited warranty - 5 years |
Environmental Parameters | |
Min Operating Temperature | 5 °C |
Max Operating Temperature | 55 °C |
Min Storage Temperature | -40 °C |
Max Storage Temperature | 70 °C |
Humidity Range Operating | 5 - 95% (non-condensing) |
Shock Tolerance (operating) | 40 g @ 11 ms |
Shock Tolerance (non-operating) | 400 g @ 2 ms |
Vibration Tolerance (operating) | 0.5 g @ 0-400 Hz |
Vibration Tolerance (non-operating) | 2.4 g @ 0-500 Hz |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
