Seagate Exos 600GB E-Class Mission Critical 15000 RPM 2.5&quo...
Seagate Exos 600GB E-Class Mission Critical 15000 RPM 2.5" 256MB Hard Drive
£212.44
35 in stock
Delivery:
Standard: 1-3 working days
Key features
  • High-performance, mission-critical enterprise servers requiring 24×7 availability
  • Highly reliable blade, pedestal, rack and tower servers
  • Transaction-based applications, like OLTP, databases, HPC and Big Data analytics
  • Power- and space-constrained data Centers
  • Compliance and data security initiatives
  • Form Factor: 2.5" SFF
  • Type: Hard drive
  • Interface Type: SAS
  • Capacity: 600GB
  • Spin Speed (rpm): 15000rpm
Product codes
The Savvio 15K.3 drive enables Tier 1 applications to read and write both random and sequential data faster. Data centers can store and access important random data up to 10% faster and sequential data up to 21% faster over previous generations, enabling them to process more transactions within a given time period.
Providing up to 300 GB capacity, the Seagate Savvio 15K.3 drive stores twice the amount of data without increasing the total number hard drives used. This helps data centers keep up with the growth of data while improving storage efficiency.
The Savvio 15K.3 drive provides protection information and self-encrypting drive options to help companies achieve corporate and/or government security compliance goals. The drive helps protect data from inadvertent change from the moment of creation until the end of life, and from exposure if the device is lost, stolen or retired.
Product Description Seagate Exos 15E900 ST600MP0006 - hard drive - 600 GB - SAS 12Gb/s
Type Hard drive - internal - Dual Port, Humidity Sensor, Low Halogen, Hot-Plug Support, 24x7 availability, advanced format 512n, Power Choice Idle Power technology, Organic Solderability Preservative, Advanced Write Caching
Capacity 600 GB
Form Factor 2.5" SFF
Interface SAS 12Gb/s
Data Transfer Rate 2400 MBps
Buffer Size 256 MB
Spindle Speed 15000 rpm
Features Dual Port, Humidity Sensor, Low Halogen, Hot-Plug Support, 24x7 availability, advanced format 512n, Power Choice Idle Power technology, Organic Solderability Preservative, Advanced Write Caching
Dimensions (WxDxH) 69.85 mm x 100.45 mm x 15 mm
Weight 230 g
Manufacturer Warranty 5-year warranty
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Seagate Exos 600GB E-C...
£212.44
