Seagate Exos X16 ST16000NM002G Hard drive 16TB SAS 12Gb/s
£528.34
38 in stock
Delivery:
Standard: 1-3 working days
Key features
  • High performance with enhanced caching, making it perfect for cloud data center and massive scale-out data center applications
  • Hyperscale SATA model tuned for large data transfers and low latency
  • PowerBalance feature optimizes Watts/TB
  • Helium sealed-drive design delivers lower total cost of ownership through lower power and weight
  • Next-generation helium side-sealing weld technology for added handling robustness and leak protection
  • Digital environmental sensors to monitor internal drive conditions for optimal operation and performance
  • Data protection and security: Seagate Secure features for safe, affordable, fast, and easy drive retirement
  • Stock Status: In Stock
Product codes
Seagate manufactures hard drives that specifically address the needs of the hyperscale storage market. As the flagship of the Seagate X class, the Exos X16 enterprise hard drives are the highest-capacity hard drives in the fleet.
Product Description Seagate Exos X16 ST16000NM002G - hard drive - 16 TB - SAS 12Gb/s
Type Hard drive - internal - PowerChoice, Dual Port, Low Halogen, Super Parity, Hot-Plug Support, T10 Data Integrity Field (DIF), PowerBalance, advanced format 512e, advanced format 4Kn, Organic Solderability Preservative, Seagate Fast Format, Helium Sealed-Drive Design
Capacity 16 TB
Interface SAS 12Gb/s
Data Transfer Rate 1.2 GBps
Buffer Size 256 MB
Spindle Speed 7200 rpm
Features PowerChoice, Dual Port, Low Halogen, Super Parity, Hot-Plug Support, T10 Data Integrity Field (DIF), PowerBalance, advanced format 512e, advanced format 4Kn, Organic Solderability Preservative, Seagate Fast Format, Helium Sealed-Drive Design
Dimensions (WxDxH) 101.85 mm x 147 mm x 26.11 mm
Weight 670 g
Manufacturer Warranty 5-year warranty
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Seagate Exos X16 ST160...
£528.34
