We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
Seagate manufactures hard drives that specifically address the needs of the hyperscale storage market. As the flagship of the Seagate X class, the Exos X16 enterprise hard drives are the highest-capacity hard drives in the fleet.
Product Description | Seagate Exos X16 ST16000NM002G - hard drive - 16 TB - SAS 12Gb/s | Type | Hard drive - internal | Capacity | 16 TB | Interface | SAS 12Gb/s | Data Transfer Rate | 1.2 GBps | Buffer Size | 256 MB | Spindle Speed | 7200 rpm | Features | PowerChoice, Dual Port, Low Halogen, Super Parity, Hot-Plug Support, T10 Data Integrity Field (DIF), PowerBalance, advanced format 512e, advanced format 4Kn, Organic Solderability Preservative, Seagate Fast Format, Helium Sealed-Drive Design | Dimensions (WxDxH) | 101.85 mm x 147 mm x 26.11 mm | Weight | 670 g | Manufacturer Warranty | 5-year warranty |
General | |
Device Type | Hard drive - internal |
Capacity | 16 TB |
Width | 101.85 mm |
Depth | 147 mm |
Height | 26.11 mm |
Weight | 670 g |
Performance | |
Drive Transfer Rate | 1.2 GBps (external) |
Internal Data Rate | 261 MBps |
Average Latency | 4.16 ms |
Reliability | |
MTBF | 2,500,000 hours |
Non-Recoverable Errors | 1 per 10^15 |
Expansion & Connectivity | |
Interfaces | 2 x SAS 12 Gb/s |
Power | |
Power Consumption | 5 Watt (idle) , 10.2 Watt (maximum) , 6.2 Watt (random read/write) |
Manufacturer Warranty | |
Service & Support | Limited warranty - 5 years |
Environmental Parameters | |
Min Operating Temperature | 5 °C |
Max Operating Temperature | 60 °C |
Shock Tolerance (operating) | 50 g @ 2 ms |
Shock Tolerance (non-operating) | 200 g @ 2 ms |
Vibration Tolerance (non-operating) | 2.27 g @ 2-500 Hz |
