Seagate Expansion 2TB USB 3.0 2.5" Portable Hard Drive
£63.46
Delivery:
Product codes
The Seagate Expansion portable drive is compact and perfect for taking with you on the go. Add more storage space to your computer instantly and take large files with you when you travel.
Set-up is straightforward: simply connect a single USB cable and you are ready to go. The drive is powered from the USB cable, so there is no need for an external power supply. Also, it is automatically recognized by the Windows operating system, so there is no software to install and nothing to configure. Saving files is easy - simply drag and drop.
Take advantage of the fast data transfer speeds with the USB 3.0 interface by connecting to a SuperSpeed USB 3.0 port. USB 3.0 is backward compatible with USB 2.0 for additional system compatibility.
Product Description Seagate Expansion STEA2000400 - hard drive - 2 TB - USB 3.0
Type Hard drive - external (portable)
Capacity 2 TB
Interface USB 3.0
Data Transfer Rate 5.0 Gbps (USB 3.0)
Power Source USB bus
Dimensions (WxDxH) 80 mm x 117 mm x 14.8 mm
Weight 170 g
Localisation Worldwide
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Seagate Expansion 2TB...
£63.46
