For everything NAS, there's IronWolf Pro - always on, always working. Built for multi-user environments and high workload rates, these NAS hard drives offer optimal reliability and system scalability.
Product Description | Seagate IronWolf Pro ST12000NE0008 - hard drive - 12 TB - SATA 6Gb/s | Type | Hard drive - internal | Capacity | 12 TB | Form Factor | 3.5" | Interface | SATA 6Gb/s | Data Transfer Rate | 600 MBps | Buffer Size | 256 MB | Spindle Speed | 7200 rpm | Features | 24x7 continuous operation, Hot-Plug Support, advanced format 512e, rotation vibration sensor, AgileArray | Dimensions (WxDxH) | 101.85 mm x 146.99 mm x 26.11 mm | Weight | 690 g | Manufacturer Warranty | 5-year warranty | Bundled with | 2 years Seagate Rescue Data Recovery |
General | |
Device Type | Hard drive - internal |
Capacity | 12 TB |
Width | 101.85 mm |
Depth | 146.99 mm |
Height | 26.11 mm |
Weight | 690 g |
Performance | |
Drive Transfer Rate | 600 MBps (external) |
Internal Data Rate | 250 MBps |
Average Latency | 4.16 ms |
Reliability | |
MTBF | 1,200,000 hours |
24x7 Operation | Yes |
Non-Recoverable Errors | 1 per 10^15 |
Expansion & Connectivity | |
Interfaces | 1 x SATA 6 Gb/s |
Compatible Bay | 3.5" |
Power | |
Power Consumption | 5 Watt (idle) , 7.8 Watt (active) , 0.8 Watt (standby) , 0.8 Watt (sleep) |
Manufacturer Warranty | |
Service & Support | Limited warranty - 5 years |
Environmental Parameters | |
Min Operating Temperature | 5 °C |
Max Operating Temperature | 60 °C |
Min Storage Temperature | -40 °C |
Max Storage Temperature | 70 °C |
Shock Tolerance (operating) | 70 g @ 2 ms |
Shock Tolerance (non-operating) | 250 g @ 2 ms |
Vibration Tolerance (non-operating) | 2.27 g @ 10-500 Hz |
