Clearing games from your console to make room for new ones? End the struggle and keep a massive collection with Game Drive for PS4. High-speed USB 3.0 gives you full-speed gaming - just like playing from the internal drive - so there's no need to throttle back.
Product Description | Seagate Game Drive for PS4 STGD4000400 - hard drive - 4 TB - USB 3.0 | Type | Hard drive - external (portable) | Capacity | 4 TB | Interface | USB 3.0 | Data Transfer Rate | 5.0 Gbps (USB 3.0) / 480 Mbps (USB 2.0) | Power Source | USB bus | Enclosure Colour | Black | Dimensions (WxDxH) | 76 mm x 113.5 mm x 20.7 mm | Weight | 225 g | Localisation | Worldwide | Manufacturer Warranty | 1-year warranty | Designed For | Sony PlayStation 4, Sony PlayStation 4 Pro, Sony PlayStation 4 Slim |
General | |
Device Type | Hard drive - external (portable) |
Capacity | 4 TB |
Width | 76 mm |
Depth | 113.5 mm |
Height | 20.7 mm |
Weight | 225 g |
Performance | |
Interface Transfer Rate | 5.0 Gbps (USB 3.0) / 480 Mbps (USB 2.0) |
Expansion & Connectivity | |
Interfaces | 1 x USB 3.0 |
Power | |
Software & System Requirements | |
OS Required | PlayStation 4 system software version 4.5 or later |
Miscellaneous | |
Cables Included | 1 x USB 3.0 cable - external - 45.72 cm |
Enclosure Material | Aluminium |
Manufacturer Warranty | |
Service & Support | Limited warranty - 1 year |
Compatibility Information | |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
