Somfy Connected Thermostat Wired
FREE DELIVERY
£119.00
Delivery:
Key features
  • Remote control your heating (Free iOS & Android app)
  • Helps you save money (energy coaching program)
  • No more surprises - estimates your heating bill
  • Adapts to your home (learns how long it takes to heat up your home)
Product codes
The connected thermostat that personalizes your comfort according to your house and your habits.
Enjoy comfort with ease
Because not everyone has the same concept of comfort, Somfy has developed the Connected Thermostat which personalises your comfort according to your house and your habits. And all that whilst helping you to reduce your energy bill. Adjust the temperature on the thermostat or using the iOS or Android smartphone app.
  • Humidity sensor
  • Geolocation function
  • Self-learning based on your home environment
  • Open window detection
  • Access management: child / adult account
MORE COMFORT WITH MORE SENSORS The connected thermostat takes into account both the temperature and humidity levels in your home, to be closer to the temperature you actually feel and offers you maximum comfort.
KEEP AN EYE ON YOUR ENERGY CONSUMPTION AND RECEIVE PERSONALIZED ENERGY COACHING. The Somfy connected thermostat analyses the energy performance of your home, the weather conditions and your usage habits. You can view in real time, on the smartphone application, the estimated amount of your energy bill. Personalized advice will be offered to improve your consumption and reduce its impact on your bill.
ENJOY MORE FREEDOM THANKS TO GEOLOCATION AND REMOTE CONTROL. The Somfy connected thermostat automatically adapts to you schedule. By activating the geolocation function, when you move away from home, the temperature decreases, and as you get closer, it increases.
ENJOY THE SOMFY ECOSYSTEM With TaHoma, combine your thermostat with your Somfy blinds for even greater efficiency. You can create a "smart" programming combining thermostat, sun sensor and blinds to save even more energy.
Contents - 1x thermostat - 1x internet gateway - 2x AA batteries - 2x 1m cable - 1x manual - 1x quickstart guide
Product Description Somfy Connected Smart Thermostat - Wired - thermostat
Product Type Thermostat
Functions Temperature measuring, humidity measurement
Power Source Battery
Internet of Things (IoT) Platform Google Home, Somfy TaHoma
Intelligent Assistant Alexa
Connectivity Wireless - Wi-Fi
Colour Grey, white
Manufacturer Warranty 5-year warranty
Dimensions (WxDxH) 10.2 cm x 3.5 cm x 9 cm
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Somfy Connected Thermo...
£119.00
