Somfy Indoor Security Camera
FREE DELIVERY
£119.00
Hurry, only 1 left in stock!
Delivery:
Standard: 1-3 working days
Key features
  • Full HD video camera: super-sharp images so that nothing escapes you
  • Motion detector: the camera starts recording as soon as it detects movement
  • Active privacy shutter: your private life is automatically shielded
  • Plug and play: installed and active within 10 minutes
  • Design: compact, clean-cut and white
  • Compatible with several services like IFTTT, Nest, Amazon Alexa & Google Assistant
  • Type: Indoor Camera
  • Compatible With: Alexa, Google Assistant, IFTTT, Nest + 1 more
  • Stock Status: In Stock
Product codes
With the Somfy Indoor Camera nothing will escape you again, because this Full HD plug and play Indoor camera records everything and sends you a push message if there is something suspicious going on. The great thing is that you can install the camera in under 10 minutes and you can set it to communicate with your smartphone via the app - it looks great too!
The camera starts recording as soon as it detects movement, you get a push message on your smartphone and you can view the images live or rewind by 10 seconds, all recordings are stored in the cloud for later viewing.
The Somfy Indoor camera is future proof and fully compatible with a width range of services like Google assistant, Amazon Alexa, IFTTT.
And then there’s the privacy shutter, as soon as you enter the room, the camera literally closes down, so everything you do in the privacy of your own home is for your eyes only. Nothing gets recorded, nothing gets stored on the cloud, zippo, niente, nada. 100% privacy guaranteed.
Finally. Have you got pets who are free to wander around? You can set up the camera in such a way that not all movements activate it.
Features:
  • Compatible with several services like IFTTT, Nest, Amazon Alexa & Google assitant
Product Description Somfy Indoor Camera - network surveillance camera
Device Type Network surveillance camera - fixed - indoor
Audio Yes: built-in speaker, built-in microphone
Dimensions (WxDxH) 9 cm x 9 cm x 4.3 cm
Weight 170 g
Connectivity Technology Wireless
Camera Colour - Day&Night
Frame Rate (max) 30 frames per second
Motion Detection Yes
Video Modes 1080p
Focal Length Control Fixed focal
Interfaces IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Platform Apple HomeKit, Nest, IFTTT, Somfy TaHoma
Intelligent Assistant Google Assistant, Alexa
Cables Included 1 - micro-USB cable - external - 3 m
Voltage DC 5 V
Features Infrared cut filter
Environmental Parameters (operating) 0 °C - 45 °C
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Somfy Indoor Security...
£119.00
