Somfy Indoor Siren
FREE DELIVERY
Somfy Indoor Siren
£119.98
Hurry, only 3 left in stock!
Delivery:
Standard: 1-3 working days
Key features
  • Alerts you, your family and neighbors from intruders
  • Loud siren to scare off uninvited people
  • Slim design and can be placed on any type of furniture in home
  • Type: Siren
  • Compatible With: Alexa, Google Assistant, IFTTT, Nest + 1 more
  • Stock Status: In Stock
Product codes
As soon as an intrusion has been detected the indoor siren will start it’s 110dB siren to deter uninvited people. The indoorsiren has a slim design and can be placed on any type of furniture in home.
The indoor siren has extended tamper detection: as soon as the siren is moved, it will activate instantly. The siren will go off and you will receive a push notification.
  • Loud 110dB siren to scare off uninvited people.
  • After 3 minutes the siren will stop automatically or you can stop it via the app.
  • Audible confirmation of arming and disarming.
  • The indoor siren has extended tamper detection: as soon as the siren is moved, it will activate instantly. The siren will go off and you will receive a push notification.
Fast and easy installation
  • Setup in minutes
  • Simply position the siren on a piece of furniture in your home
  • Automatic system recognition when installed.
Power supply
  • 4 D Alkaline batteries included.
  • Battery life: 2-year battery life with normal use.
What's included?
  • 1x Somfy® indoor siren
  • 4 alkaline LR20 batteriestect Indoor Siren
Product Description Somfy Protect Indoor Siren - siren
Product Type Siren
Environment Indoor
Power Source Battery
Connectivity Wireless
Supported Host Device OS iOS, Android
Dimensions (WxDxH) 17.5 cm x 17.5 cm x 4.5 cm
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Somfy Indoor Siren
£119.98
