Somfy Intellitag
FREE DELIVERY
Somfy Intellitag
£39.99
16 in stock
Delivery:
Standard: 1-3 working days
  • Type: Vibration sensor
  • Compatible With: Alexa, Google Assistant, IFTTT, Nest + 1 more
  • Stock Status: In Stock
Product codes
IntelliTAG anti-intrusion sensor
Only IntelliTAG™ uses multiple sensors and an advanced algorithm to analyze vibration patterns and detect the first sign of a break-in BEFORE a door or window is opened.
IntelliTAG can tell the difference between normal events like a knock at the door or a ball bouncing, and potential threats, like drilling or hammering: no more false alarms. Within nanoseconds of the break-in attempt, IntelliTAG triggers the siren and sends an alert to your smartphone.
Universal adaptability for sliding or swinging doors or windows, one-step adhesive installation, and tamper protection.
Fast and easy installation
Sets up in minutes: Simply place it on any window or door. Connect with Smartphone. And go!
Radio
Radio communication between IntelliTAG and Link ensures system maintenance. Tamper protection in case of radio interference.
Power supply
  • Batteries: 1 x AA battery with 12 month life (under normal use conditions)
  • You will be notified automatically when power supply is low
Compatibility: - Somfy One - Somfy Home Alarm
Product Description Somfy IntelliTAG - vibration sensor
Product Type Vibration sensor
Power Source Battery
Connectivity Wireless
Dimensions (WxDxH) 6 cm x 2.8 cm x 1.35 cm
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Somfy Intellitag
£39.99
