Somfy Keyfob
FREE DELIVERY
Somfy Keyfob
£24.99
Delivery:
Standard: 1-3 working days
  • Type: Remote control
  • Compatible With: Alexa, Google Assistant, IFTTT, Nest + 1 more
  • Stock Status: In Stock
Product codes
Key fob automatically disarms your alarm and recognizes authorized users. It replaces the keypad used with more traditional security systems, which helps to avoid accidentally setting off the alarm.
Give a keyfob to family members, your housekeeper, or trusted neighbors. It alerts you anytime someone enters or leaves your home. Its 4 buttons let you arm, disarm, or set the system to partial mode. It also has a 1-click panic button that sends a silent alert via email or SMS, or triggers the alarm. To prevent false alarm, automatic deactivation only works if you enter through a door which is equipped with an intellitag.
Power supply
  • 1x CR2032 battery
Radio
  • Connects with Somfy One or Somfy Home Alarm via Bluetooth.
Battery life
  • 12 month life (under normal use conditions)
  • You will be notified automatically when power supply is low
Compatibility:
  • Somfy One
  • Somfy Home Alarm
Product Description Somfy Key Fob - remote control
Product Type Remote control
Power Source Battery
Connectivity Wireless
Dimensions (WxDxH) 3.4 cm x 3.4 cm x 1 cm
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
Somfy Keyfob
£24.99
