Somfy One
FREE DELIVERY
Somfy One
£189.99
Delivery:
Standard: 1-3 working days
Express: Delivered on Monday
Express Delivery:
  • 00 h
  • 00 m
  • 00 s
Key features
  • Powerful, intruder-deterrent siren
  • A photo and video as proof
  • A community available to intervene
  • Protecting your privacy
  • Easy to install
  • Accurate detection
  • Type: Home security system
  • Compatible With: Alexa, Google Assistant, IFTTT, Nest + 1 more
  • Stock Status: In Stock
Product codes
Somfy One - wireless alarm system with full HD camera, siren, motion detector and privacy protection.
With Somfy One, you’ll have everything you need in one go when it comes to your security. And that is quite handy. Somfy One is a fully stand-alone system. You simply install it in a strategically smart spot, activate it using the Somfy Protect app, and you’re good to go!
As soon as the camera detects movement, the alarm goes off and you get a push message on your smartphone. And you can view the images live and rewind by 10 seconds.
The siren that goes off will provide the deterrent you’re looking for. But you can always warn the police straight away too. And what if you’re not reachable? No problem. You can add several people to the app who will then receive a push message if there’s something suspicious going on, so that they can take steps immediately. By the way, you can also turn the siren off via the app.
And what if you’ve got pets? You can configure the Somfy One so that the camera will not react if your favourite pet happens to wander past the lens.
Do you value your privacy? Somfy One takes that into account. Because as soon as you enter the room, the camera shutter closes. So no one can watch what’s going on. Easy to expand the Somfy One with other Somfy Protect accessories, such as a window or door sensor, for instance.
Features:
  • Full HD video camera; pin-sharp images that ensure nothing escapes you
  • 90 DB siren: fully integrated and loud enough to scare off intruders
  • Motion detector: the camera starts recording as soon as it detects movement
  • Active privacy shutter: your private life is automatically shielded
  • Plug and play: the system is active and you’ll be done within 10 minutes!
  • Compatible: so you can expand it with various nifty Somfy Protect accessories
Product Description Somfy ONE - network surveillance camera
Device Type Network surveillance camera - fixed
Audio Yes: built-in speaker, built-in microphone
Dimensions (WxDxH) 9 cm x 9 cm x 11 cm
Weight 260 g
Connectivity Technology Wireless
Camera Colour - Day&Night
Frame Rate (max) 30 frames per second
Motion Detection Yes
Video Modes 1080p
Interfaces IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, Bluetooth 4.0, 868MHz radio
Platform Nest, IFTTT, Somfy TaHoma
Intelligent Assistant Google Assistant, Alexa
Cables Included 1 - micro-USB cable - external - 3 m
Voltage DC 5 V
Features Motion Detection Technology, built-in siren
Environmental Parameters (operating) 0 °C - 45 °C
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Somfy One
£189.99
