Somfy Outdoor Camera - Anthracite
FREE DELIVERY
THE OUTDOOR CAMERA WITH A BUILT-IN SIREN
£249.00
Colours:
Hurry, only 1 left in stock!
Delivery:
Standard: 1-3 working days
Key features
  • Built-in loud siren
  • HDR function to compensate for brightness problems
  • Built-in speaker and microphone
  • Stock Status: In Stock
Product codes
Documents
Somfy’s smart outdoor camera - the smartest form of security
The thought of someone breaking into your home, prowling around your house, looking for valuables, perish the thought! What you really want is for the thieves or burglars to just keep off your property.
The camera also comes with a smart activation function. When you get back home, the system will recognise you and switch itself off, and if you go out again, you’ll get a reminder via the app on your smartphone to re-activate the camera. That’s convenience for you!
The outdoor camera with a built-in siren
Somfy Outdoor Camera is the most deterrent outdoor camera on the market, with a 110 dB built-in siren and the option to link it to an outdoor lighting system.
The Somfy outdoor camera forms part of the complete Somfy Plug and Play security products range and is compatible with Smart Home systems, such as Works With Nest, IFTTT, Amazon Alexa and Google.
Features:
  • Scare burglars off with smart motion detection and a siren
  • Full HD camera with night vision
  • Powerful siren (110 dB)
  • Talk to intruders via the built-in speaker
  • Motion detection: immediately starts recording when motion is detected
  • Image storage in the cloud
  • Connect via powersupply or external lighting
  • Compatible with known Smart Home systems
Product Description Somfy Outdoor Camera - network surveillance camera
Device Type Network surveillance camera - fixed - outdoor - weatherproof
Audio Yes: built-in speaker, built-in microphone
Camera Mount Type Wall mount
Dimensions (WxDxH) 14.725 cm x 8.5 cm x 15.08 cm
Weight 512 g
Colour Anthracite grey
Connectivity Technology Wireless
Camera Colour - Day&Night
Max Resolution 1920 x 1080
Frame Rate (max) 30 frames per second
Motion Detection Yes
Video Modes 1080p
Interfaces IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, Bluetooth 4.0
Voltage AC 120/230 V
Features Motion Detection Technology, reset button, High Dynamic Range (HDR), built-in siren
Environmental Parameters (operating) -20 °C - 50 °C
Resources
The following resources are available for the Somfy Outdoor Camera - Anthracite
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Somfy Outdoor Camera -...
£249.00
