Somfy Outdoor Siren
FREE DELIVERY
Somfy Outdoor Siren
£129.99
Delivery:
Standard: 1-3 working days
Key features
  • For outdoor use on any surface
  • Audible confirmation of arming and disarming
  • Auto-protection if moved or removed when system is activated
  • Fast and easy installation
  • Automatic system recognition when installed
  • Type: Siren
  • Compatible With: Alexa, Google Assistant, IFTTT, Nest + 1 more
  • Stock Status: In Stock
Product codes
Bundle deals (1)
TP LINK KASA SMART WIFI POWER STRIP
= £154.97
Save £10.00
In the event of a detection, this outdoor siren emits a loud noise and bright flash to warn neighbors and prevent break-ins before they occur.
Product Description Somfy Protect Outdoor Siren - siren
Product Type Siren
Environment Outdoor
Power Source Battery
Connectivity Wireless
Dimensions (WxDxH) 22 cm x 22 cm x 5.5 cm
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Somfy Outdoor Siren
£129.99
