Somfy Protect Home Alarm Premium
FREE DELIVERY
£469.00
Delivery:
Key features
  • All-round alarm system: every nook and cranny is protected, and it comes complete with a siren
  • IntelliTAG: smart door/window sensor that warns you BEFORE the intruder has broken in
  • Motion detector: reacts immediately to unexpected temperature differences while ignoring pets
  • Push messages: tell you about suspicious activities immediately via your smartphone
  • Easy to install: sensors can be placed on or stuck to a surface
  • Plug and Play: installed and active within 10 minutes
  • Type: Home security system
  • Compatible With: Alexa, Google Assistant, IFTTT, Nest + 1 more
Product codes
With the Somfy Home Alarm Pack, you can protect every nook and cranny in your house. And you’re warned even before the intruder has broken in. If there is movement or a burglary, the sensors send a push message and both the loud indoor- and outdoor -siren goes off. Unless it’s your pet: the camera ignores animals weighing up to 25 kg. You have two special key fobs that you can use to switch the alarm on and off. And as soon as you get close to your house, the system ‘sees’ that you’re standing in front of the door and is automatically switched off. In addition, the Somfy Home Alarm Pack can be expanded to include additional cameras and sensors.
  • IntelliTAG™: smart door/window sensor that warns you BEFORE the intruder has broken in
  • Plug and play: installed and active within 10 minutes
Pack content
  • 1x Link
  • 1x Indoorsiren
  • 1x Outdoorsiren
  • 2x IntelliTag
  • 2x Key Fob-Badge
  • 2x Movementdetector
  • 1x Manual
  • All required batteries
Product Description Somfy Protect Home Alarm Premium - home security system
Product Type Home security system
Power Source Battery
Package Content Door and window sensor, 2 x remote controls, 2 x motion sensors, Wi-Fi hub, indoor siren, outdoor siren
Connectivity Wireless - 802.11b/g/n
Frequency Band 2.4 Ghz
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
Somfy Protect Home Ala...
£469.00
