Somfy Thermostatic Valve IO
FREE DELIVERY
£79.99
Delivery:
Standard: 1-3 working days
  • Type: Smart radiator valve
  • Stock Status: In Stock
Product codes
Using the Somfy Thermostatic Radiator Valve you can have the right temperature in every room. Simply change the desired temperature on the valve or using the Somfy TaHoma.
  • Save Energy - only heat selected rooms
  • Optimize radiator control - smart placement of the temperature sensors secures accurate temperature measuring
  • Quiet yet powerful - the motor in the radiator valve is designed for optimal sound levels
  • Timer function - set each radiator individually according to your schedule
Operate manually or from Somfy TaHoma
Operable from Somfy app when combined with: TaHoma
NOTE: remote io or TaHoma not included. The screen will be upside down on UK radiators with the valve pointing vertically
Product Description Somfy Thermostatic Radiator Valve - smart radiator valve
Product Type Smart radiator valve
Functions Control heating systems
Power Source Battery
Connectivity Wireless
Frequency Band 868.25 - 868.95 Mhz
Dimensions (WxDxH) 5.5 cm x 8.7 cm x 4.8 cm
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Somfy Thermostatic Val...
£79.99
