Beam: The Small But Smart TV Soundbar
Enrich all your entertainment with the latest generation of Sonos compact smart soundbar, now with Dolby Atmos.
Experience panoramic sound and crystal clear dialogue for shows, movies, and games. And when the TV is off, stream music and more from all your favorite services. Control is easy with the Sonos app, your voice, and Apple AirPlay 2. Add speakers to create a wireless surround sound system and enjoy multiroom listening. Everything connects over WiFi.
Exceptional sound all around
Dolby Atmos maps sounds in space for a 3D effect so you experience planes as if they're flying overhead, hear footsteps moving across the room, and feel the score surround you.
Crystal clear dialogue
Oscar-winning sound engineers helped fine-tune Beam to make sure you hear every word and can always follow the story. For even greater clarity when characters whisper or the action intensifies, turn on Speech Enhancement in the Sonos app.
High quality even at low volumes
Advanced audio processing ensures balanced sound from wall to wall at any volume level. When you want to watch TV but need to keep it down, turn on Night Sound in the app to reduce the intensity of loud effects and enhance quieter ones.
Made for music
Stream from all your favourite services with detailed stereo sound, and feel more dimensions of the song with support for the highest-resolution formats, including Dolby Atmos Music.
Breeze through setup
Go from unboxing to unbelievable sound in minutes with only two cables and step-by-step guidance from the Sonos app.
Tuned to perfection
Trueplay tuning technology adapts the sound for the unique acoustics of the room so your content always sounds just the way it should.
Freedom of control
Sonos app
Connect all your streaming services, discover new music on Sonos Radio, and personalise settings.
TV remote
The soundbar syncs with your existing remote for streamlined control and no extra clutter.
Touch
Tap or swipe the top of the soundbar to pause the music, adjust the volume, skip a track, and more.
Apple AirPlay 2
Send sound directly from your iPhone, iPad, or Mac, then ask Siri to turn it up from your device.
Hands-free help
Ask Amazon Alexa or Google Assistant to set timers, check the news, control your smart home devices, and more.
Product Description | Sonos Beam (Gen 2) - sound bar - wireless | Product Type | Sound bar | Enclosure Design | Passive radiator | Speaker Type | Active | Amplifier Output Power | D | Amplifier | Integrated | Interfaces | Ethernet, Fast Ethernet, Wi-Fi | Intelligent Assistant | Alexa built-in - direct | AirPlay | Yes | Audio Formats | PCM | Colour | Black | Built-in Decoders | Dolby Digital, Dolby Digital Plus, Dolby TrueHD, Dolby Atmos | Power | AC 100-240 V (50 - 60 Hz) | Dimensions (WxDxH) | 65.1 cm x 10 cm x 6.9 cm | Weight | 2.8 kg |
General | |
Microphone | 5 far field microphones |
Enclosure Colour | Black |
Design Features | Matte finish, touch control |
Speaker System | |
Amplifier Class | D |
Audio Return Channel (ARC) Capability | Yes |
Interfaces | IEEE 802.3 (Ethernet), IEEE 802.3u (Fast Ethernet), IEEE 802.11b/g/n/ac |
AirPlay | Yes |
Recommended Placing | On-wall mounted, desktop |
Controls | Volume, play/pause, next track, previous track, mute microphone |
App-Controlled | Yes |
Internet of Things (IoT) | |
Internet of Things (IoT) Compatible | Yes |
Communications Technology | Wi-Fi |
Intelligent Assistant | Alexa built-in |
Voice Control | Direct |
Speaker System Details | |
Driver Details | Sound bar: tweeter driver , Sound bar: 4 x mid/woofer driver , Sound bar: 3 x Passive Radiator |
Connections | |
Connector Type | HDMI (19 pin HDMI Type A) , LAN (RJ-45) |
Miscellaneous | |
Included Accessories | HDMI cable, audio (optical) adapter |
Power | |
Power Source | Integrated power supply |
Voltage Required | AC 100-240 V (50 - 60 Hz) |
Dimensions & Weight | |
Width | 65.1 cm |
Depth | 10 cm |
Height | 6.9 cm |
Weight | 2.8 kg |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
