Smart Sound
The powerful smart speaker with voice control built-in.
Sonos One gives you rich, room-filling sound and has the Google Assistant and Amazon Alexa built right in for simple voice control of your music and more. Ask for songs while you cook. Easily turn the volume up while you’re in the shower. You can even request a lullaby, out loud, when you’re putting the kids to bed.
Sonos One connects to the Google Assistant or Amazon Alexa over WiFi. Just plug in the speaker and follow step-by-step instructions in the app. In minutes you’re ready to play music, get news and answers, manage your smart devices, and enjoy all the conveniences of your voice assistant with nothing but your Sonos One.
Anyone in your home can take charge of the music. Kids can call out their favorite sing-alongs. Friends can skip or replay tracks and adjust audio settings. Guests can request their favorite songs in real time. No matter who says it, Sonos plays it.
Brilliant sound for every room
The compact design fits just about any space. Put it on your kitchen countertop or tuck it away on your office bookshelf. It's humidity resistant so you can even put it in the bathroom.
Voice control
The Google Assistant and Amazon Alexa are built right-in so you can play music, check news, set alarms, get your questions answered, and more, completely hands-free.
Stereo sound with two
Pair two Sonos Ones together in the same room for stereo separation and more detailed sound. Use a pair as rear home cinema surrounds with Playbar, Playbase, or Beam.
Build your system
Easily connect Sonos speakers in different rooms over WiFi to create a home sound system that brings every room and everyone together.
Brilliant sound
Enjoy clear, richly detailed sound that fills the room at any volume.
Easy to use
Setup takes minutes, and control is simple with the Sonos app, AirPlay 2, and your voice.
Listen your way
Customise your system and play what you want, where you want.
Introducing Sonos Radio
Enjoy thousands of stations, including live radio and exclusive programming, on your system through the Sonos app.
Product Description | Sonos One (Gen2) - smart speaker | Product Type | Smart speaker | Localisation | United Kingdom | Speaker Type | 2-way - active | Interfaces | Ethernet, Fast Ethernet, Wi-Fi | Intelligent Assistant | Alexa - direct | Audio Formats | WAV, WMA, AAC, AIFF, Ogg Vorbis, MP3, FLAC, Apple Lossless, AAC + | Colour | White | Power | AC 120/230 V (50/60 Hz) | Dimensions (WxDxH) | 11.97 cm x 11.97 cm x 16.145 cm | Weight | 1.76 kg | Manufacturer Warranty | 2-year warranty |
General | |
Microphone | 6 microphones array |
Enclosure Colour | White |
Grille Colour | Matt white |
Speaker System | |
Connection Options | Bi-amping |
Multiroom | Yes |
Amplifier | Integrated |
Interfaces | IEEE 802.3 (Ethernet), IEEE 802.3u (Fast Ethernet), IEEE 802.11b/g |
Controls | Volume, play/pause, next track, previous track, mute microphone |
Internet of Things (IoT) | |
Internet of Things (IoT) Compatible | Yes |
Intelligent Assistant | Alexa |
Voice Control | Direct |
Speaker System Details | |
Driver Details | Tweeter driver , Mid-range driver |
Connections | |
Connector Type | LAN (RJ-45) |
Miscellaneous | |
Included Accessories | Ethernet cable |
Power | |
Power Source | Integrated power supply |
Voltage Required | AC 120/230 V (50/60 Hz) |
Dimensions & Weight | |
Width | 11.97 cm |
Depth | 11.97 cm |
Height | 16.145 cm |
Weight | 1.76 kg |
Dimensions & Weight (Shipping) | |
Shipping Width | 17.4 cm |
Shipping Depth | 17.4 cm |
Shipping Height | 24.7 cm |
Shipping Weight | 2.39 kg |
Manufacturer Warranty | |
Service & Support | Limited warranty - 2 years |
Customer return - item has been opened but is in excellent condition
Ref: FWZM 046541 |
Accessories | |
Packaging | |
Functional | |
Software | |
Manuals | |
£135.82
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
