Sony 5000 Lumens WUXGA Resolution 3LCD Technology Install Pro...
Sony 5000 Lumens WUXGA Resolution 3LCD Technology Install Project
£2,424.00
Hurry, only 2 left in stock!
Delivery:
Standard: 1-3 working days
Key features
  • Very high image quality with BrightEra 3LCD projection engine
  • Advanced picture refinement technologies
  • Crisp, detail-packed WUXGA resolution images
  • Hassle-free automatic filter cleaning
  • Energy-saving lamp dimming mode
  • Supports HDBaseT
  • Create super-size displays with edge blending
  • Project onto non-flat surfaces with image warping
  • Quiet operation
  • Slim, attractive blend-in design
  • Choice of picture modes
  • Simple set-up with friendly installation menu
  • Project side by side
  • Portability: Non-portable
  • Stock Status: In Stock
Product codes
Bring presentations to life with impressive brightness and picture quality - plus easy, flexible integration and powerful picture features.
The VPL-FH60 installation projector is ideal for a wide range of business, education and entertainment applications. The energy-efficient High Pressure Mercury (HPM) lamp source is teamed with Sony's advanced BrightEra 3LCD projection engine, delivering extremely bright, detail-packed WUXGA resolution images with generous 5000 lumens brightness and rich, stable colors. Reality creation and contrast enhancer technologes fine-tune image quality even further to assure exceptional clarity, realism and punch with every presentation.
With a stylish blend-in design, neat cable management and low fan noise, the VPL-FH60 integrates smoothly into almost any environment - from academic institutions, corporate, medical training and public sector organizations to visitor attractions and retail spaces. Easy set-up's assisted by a friendly installation menu.
Product Description Sony VPL-FH60 - 3LCD projector - standard lens - LAN
Device Type 3LCD projector - 1080p
Brightness (White) 5000 lumens
Brightness (Colour) 5000 lumens
Contrast Ratio 2000:1
Resolution WUXGA (1920 x 1200)
Native Aspect Ratio 16:10
Lens Standard lens
Lens Shift Direction Horizontal, vertical
Bulb type Ultra high-pressure mercury 280 Watt
Bulb life cycle Up to 3000 hour(s) - normal mode ¦ Up to 4000 hour(s) - economic mode
Video Input RGB, composite video, component video (NTSC, SECAM, PAL, PAL-N, PAL-M, NTSC 4.43, PAL 60, NTSC 3.58), LAN
Video Modes 1080/24p, 1080/60i, 480/60p, 720/60p, 1080/50i, 720/50p, 576/50p, 1080/50p, 1080/60p, 480/60i, 576/50i
Power AC 120/230 V (50/60 Hz)
Power Consumption Operational 416 Watt
Dimensions (WxDxH) 46 cm x 51.5 cm x 16.9 cm
Weight 13 kg
Pricing Type Refurbished - Grade A
Manufacturer Warranty 1-year warranty
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Sony 5000 Lumens WUXGA...
£2,424.00
