Bring presentations to life with impressive brightness and picture quality - plus easy, flexible integration and powerful picture features.
The VPL-FH60 installation projector is ideal for a wide range of business, education and entertainment applications. The energy-efficient High Pressure Mercury (HPM) lamp source is teamed with Sony's advanced BrightEra 3LCD projection engine, delivering extremely bright, detail-packed WUXGA resolution images with generous 5000 lumens brightness and rich, stable colors. Reality creation and contrast enhancer technologes fine-tune image quality even further to assure exceptional clarity, realism and punch with every presentation.
With a stylish blend-in design, neat cable management and low fan noise, the VPL-FH60 integrates smoothly into almost any environment - from academic institutions, corporate, medical training and public sector organizations to visitor attractions and retail spaces. Easy set-up's assisted by a friendly installation menu.
Product Description | Sony VPL-FH60 - 3LCD projector - standard lens - LAN | Device Type | 3LCD projector - 1080p | Brightness (White) | 5000 lumens | Brightness (Colour) | 5000 lumens | Contrast Ratio | 2000:1 | Resolution | WUXGA (1920 x 1200) | Native Aspect Ratio | 16:10 | Lens | Standard lens | Lens Shift Direction | Horizontal, vertical | Bulb type | Ultra high-pressure mercury 280 Watt | Bulb life cycle | Up to 3000 hour(s) - normal mode , Up to 4000 hour(s) - economic mode | Video Input | RGB, composite video, component video (NTSC, SECAM, PAL, PAL-N, PAL-M, NTSC 4.43, PAL 60, NTSC 3.58), LAN | Video Modes | 1080/24p, 1080/60i, 480/60p, 720/60p, 1080/50i, 720/50p, 576/50p, 1080/50p, 1080/60p, 480/60i, 576/50i | Power | AC 120/230 V (50/60 Hz) | Power Consumption Operational | 416 Watt | Dimensions (WxDxH) | 46 cm x 51.5 cm x 16.9 cm | Weight | 13 kg | Pricing Type | Refurbished - Grade A | Manufacturer Warranty | 1-year warranty |
General | |
Networking | Ethernet |
Projector | |
Image Size | 102 cm - 1524 cm |
Throw Ratio | 1.39 - 2.23:1 |
Resolution | WUXGA - WUXGA (1920 x 1200) |
Display Format | 6,912,000 pixels (1920 x 1200) x 3 |
Max Sync Rate (V x H) | 92 Hz x 92 kHz |
Controls & Adjustments | Keystone correction |
OSD Languages | Hungarian, Indonesian, Thai, Chinese (traditional), Chinese (simplified), Vietnamese, Farsi, English, German, French, Italian, Norwegian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Arabic, Japanese, Korean |
Features | Picture Muting, Edge blending, High-bandwidth Digital Content Protection System (HDCP), Side-by-Side, 3LCD Technology, BrightEra, ECO Lamp Dimming, Reality Creation, Image Warping |
Lens | |
Type | Standard lens |
Focus Type | Powered |
Zoom Type | Powered |
Zoom Factor | 1.6x |
Keystone Correction Direction | Horizontal, vertical |
Vertical Keystone Correction | -30 / +30 |
Horizontal Keystone Correction | -30 / +30 |
Lens Shift Type | Powered |
Vertical Lens Shift | 5% / 60% |
Horizontal Lens Shift | 32% / 32% |
Video Input | |
TV System | NTSC, SECAM, PAL, PAL-N, PAL-M, NTSC 4.43, PAL 60, NTSC 3.58 |
Analogue video Signal | RGB, composite video, component video |
Video Interfaces | VGA, HDMI, component video, composite video, DVI |
LAN and Wireless Image Transferring Protocols | Wired LAN |
DVI-D with HDCP Input | Yes |
Expansion / Connectivity | |
Interfaces | 1 x component video / RGB input - 15 pin HD D-Sub (HD-15) , 1 x audio line-in - mini-phone stereo 3.5 mm , 1 x DVI-D input - 24+1 pin digital DVI , 1 x HDMI input - 19 pin HDMI Type A , 1 x HDBaseT - RJ-45 , 1 x composite video input - BNC , 1 x VGA output - 15 pin D-Sub (DB-15) , 2 x audio line-out - mini-phone stereo 3.5 mm , 1 x DVI-D output - 24+1 pin digital DVI , 1 x serial RS-232C - 9 pin D-Sub (DB-9) (management) , 1 x network - RJ-45 |
Miscellaneous | |
Included Accessories | Remote control |
Power | |
Power Source | AC |
Nominal Voltage | AC 120/230 V (50/60 Hz) |
Power Consumption Stand by | 0.5 Watt |
Dimensions & Weight | |
Width | 46 cm |
Depth | 51.5 cm |
Height | 16.9 cm |
Weight | 13 kg |
Manufacturer Warranty | |
Service & Support | Limited warranty - 1 year |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 40 °C |
Humidity Range Operating | 20 - 80% (non-condensing) |
Sound Emission | 28 dB |
